02-06-2008, 08:35 AM
#3
Re: Replacing Rear Axle Seal?
Yeah, you only have 48k so have the dealer fix it. And if they give you any flack about the lift/tires.
Explain this to them:
First of all, the lift kit doesn't affect the axle bearings/seals in any way, so they can get that thought out of their minds.
Second, the larger tires could potentially cause a bearing failure. You don't have a bearing failure though, you have a seal failure. So it wasn't the wheel/tire that caused the seal failure. What I'm saying is that the wheel/tire would cause the bearing to fail, which in turn would cause the seal to fail. That's not the case here though. You ONLY have a seal failure, which is a well documented problem.
They should fix it and send you on your way if they're any kind of dealership though.
'Congressmen who willfully take actions during wartime that damages morale and undermine the military are saboteurs and should be arrested, quickly tried and hanged!" -Abraham Lincoln
"The American Indians found out what happens when you don't control immigration"
