Old 02-06-2008, 09:00 AM   #4 (permalink)
BK19702
BK19702's Avatar
Re: Replacing Rear Axle Seal?
Originally Posted by 54warrior
Yeah, you only have 48k so have the dealer fix it. And if they give you any flack about the lift/tires.
Explain this to them:
First of all, the lift kit doesn't affect the axle bearings/seals in any way, so they can get that thought out of their minds.
Second, the larger tires could potentially cause a bearing failure. You don't have a bearing failure though, you have a seal failure. So it wasn't the wheel/tire that caused the seal failure. What I'm saying is that the wheel/tire would cause the bearing to fail, which in turn would cause the seal to fail. That's not the case here though. You ONLY have a seal failure, which is a well documented problem.
They should fix it and send you on your way if they're any kind of dealership though.
...+1 and then file a complaint with the NHTSA about the axle seal leak. There is a sticky in the drive train forum on how to do it.
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
BK19702 is offline   Reply With Quote
