Originally Posted by Derodeo
Fortunately for someone like myself who's after the sunroof but not the navigation system, you "only" have to add an extra $3000 Cdn. What I'm curious about is how the sunroof affects the storage compartments on the ceiling(are there any?) and do you still have enough headroom with the sunroof installed? I believe from the specs, you lose 1.3" with the sunroof. I'm 6'2" and a lot of sunroof equipped vehicles pose a problem.
I'm 6'4" and have plenty of room. I'm not a big fan of sunroofs (I had one of the old style flip up ones that leaked badly on a Jeep CJ7 that I finally ended up caulking shut after numerous trips to the dealer), but I couldn't find one available with the other stuff I wanted, without a sunroof. The only storage compartment on the ceiling is a little sunglass case that is forward of and not affected by the sunroof. The DVD screen is rearward of and not affected by the sunroof.
4 x 4, Crew Cab LE, sunroof, NAV, DVD, Off-Road, Big Tow
Where exactly is the sunroof drain tube to be found? Is it underneath the frame somewhere on the passenger's side? I would like to check this out before the flood.
