Old 02-08-2008, 12:27 PM   #5 (permalink)
espins
Re: 2005 Titan 30k maintenance - $725?!?
Thanks for the quick responses.
Here is the breakdown
Inspect:
Tire Wear Front
Tire Wear Rear
Drive Shaft Joint Boots
Struts and shocks
Brakes
Brake Hydraulic System
Emergency Brake
Muffler and exhaust
Engine and Transmission oil
Drive Belts
Radiator and coolant
Radiator Hoses
Heater Hoses
Battery Cables
Spark plug wires
Air and Fuel filters
Wiper blades
Head lights
Stop, tail and turn signals
Heater and AC operation
Restraint System
Lubricate
Doors
Locks
Hinges
Chassis
Adjust
Tire Pressure
Rotate/Balance Tires
Emergency Brake
Replace
Engine Oil
Oil Filter
Anti-Corrosive Battery Term pads and Service Battery
Engine Coolant Service
Air and Fuel Filters
Transmission Fluid
Differential Fluids
Transfer Case Fluid
In Cabin Micro-Filter
Install Premium Fuel System Cleaner to Fuel Tank
Install Premium Engine Oil Treatment to Oil.
espins is offline   Reply With Quote
