Thread: Agonizing !
Old 02-24-2004, 11:29 PM   #5 (permalink)
pluckyew
pluckyew's Avatar
do the Titan
you'll get maybe about 18 mpg on a Canyon while getting about 14 mpg on the Titan: big deal, maybe 25% difference, in theory. In reality, the little Canyon motor, you'll be pushing harder & revving higher (for less performance & satisfaction) and end up with closer mpg milage numbers.
I've owned two Wranglers ('95 & '00). I've had a 1995 Ford 150 with 5.7 v8 and another Ford 150 Edie Bauer V6 (don't ask why ). Titan gets better actual milage than all four.
look, you need a truck or you don't. Since you need to haul a trailer you might as well enjoy the ride and hauling on the 5.6 v8 Titan .
some have reported getting the same milage on a Titan as they've gotten on thier Pathfinders. clashofthetitans, what gas milage are you getting on your Pathfinder? I'm guessing 15~19 mpg? A 4x2 Titan gets the same.
i'd still get the Titan even if gas was $3 or $4 bucks gallon (but i'd ditch my Wranger -- gees no one really needs two 4x4s -- and get a VW TDI diesel (38 mpg) from Nevada as the 2nd car for our family).
Colorado mpg notes:
Code L52; Cylinders 5; Liters 3.5; Fuel Induction 20V MFI; HP 220; Torque 225; EPA City 19*; EPA Hwy 24*. *2WD Models; 18/23 on 4WD Models. Curb Weight 3802-lbs. Towing Cap., 4000-lb. Max. (When Properly Equipped)
from http://www.kbb.com/kb/ki.dll/kw.kc.n...&&Pick-ups&&nc
Twenty Aught Four Titan KC 4x4 SE, Smoke: Off-Road/Big-Tow/Utility/Bench 6-seater.
"The state that separates its scholars from its warriors will have its thinking done by cowards, and its fighting by fools," Thucydides.
pluckyew is offline   Reply With Quote
