Originally Posted by tech12volt
There should be a bluw with white stripe wire on the harness and one coming from the new radio. connect these together.
Thanks...that was an easy fix. I have sound now, but there's quite a bit of background static. The only thing I can think of to cause that would be that I connected both the radio and amp ground from the harness to the same ground wire from the radio instead of directly to the chasis. Does that make sense or do you have another idea of what may be causing the static? Thanks again!
