I don't think this is quite right.
Originally Posted by mtnman
... It sounds like the XE will handle the 4k lb. boat/trailer I have now using a class III setup and a heavier bumper camper if I later add the class IV accessories...
The class III receiver that bolts to the frame of the truck is not the same as the class IV receiver. The class IV is much stronger and that it why you can tow more with it. It isn't the accessories that make the difference between class III & class IV. I had a class III (5000lbs) on my Fronty and a weight distributing platform (this holds the ball) for my 23' TT and the weight dist. accessories were only rated for 5000 lbs.
SO, know you can't install a class III receiver on the truck and then later add the class IV weight distributing system (platform, chains, and steel rods) to get a full class IV system. You must change the receiver bolted to your truck to a class IV.
Hope this helps!
Titan CC LE 4x4 Sparkle Red Bug Guard and every option except off-road, DVD, Sunroof & Nav.
Add ons: Sliding bed extender, Leer 180 cap, BFG KO's
Just passed the 57,000km mark!
Born on 03/04
Now it is up for sale - or at least the BFGs and the Cap!
2008 Suburban 2500 LS
