Old 02-15-2008, 12:10 PM   #2 (permalink)
MFresh
MFresh's Avatar
Re: will chevy 6 lugs fit on a titan?
As far as the lug pattern should be no problem. I think it's the same bolt pattern just different studs. My cousin has my OR wheels on his 06 Chevy Tahoe no problems.
You say you have the PRG's (which ones? mini,leveling, PRG 4" w/CST). You probably can fit the tires with the 4" CST, but would have problems with anything less. Another problem is what is the BS/Offset of the wheels? Too much offset you'll rub the spindle. Negative offsets, depends on how much you wanna cut!
MFresh is offline   Reply With Quote
