Old 02-19-2008, 09:54 AM   #6 (permalink)
thclimer
thclimer's Avatar
Re: Firestone Airbags
As HVT has pointed out you should be able to get away without them because you should be using a weight distribution hitch for loads over 5,000 pounds.
I also purchased mine from Suspension Connection. I think they were about about $225, and they were simple to install. I did not get the on-board compressor, while its convenient to have, it will add to the cost.
If you ever thought you were going to tow a lot in the future or tow heavier loads I would definitely recommend them.
2006 LE KC 4X4 BT, Radiant Silver
Prodigy Brake Controller
Equalizer Hitch
Scan Gauge II
Firestone Air Springs
Bridgestone Dueler A/T Revo's
A.R.E. Z-Series Cap
thclimer is offline   Reply With Quote
