Old 02-19-2008, 09:16 PM   #44
MikeB
MikeB's Avatar
Re: Dash Air Bag Sensor Reset
I just had to do this and it took several dozen tries to get it right. I think I came up with a procedure that will help alot of you with bad timing like myself.
First, you know how when you leave your key in the ignition in the off position with the door open your truck beeps at you? "beep beep beep beep ----beep beep beep beep----beep beep beep beep" Well, you can use that as a timer.
Open the drivers side door and put the key in the ignition.
Turn it to the On position and watch the air bag light. It stays on for several seconds and starts blinking. Watch it closely. As soon as it blinks ON for the first time, IMMEDIATELY shut off the ignition.
Wait for 5 "beep beep beep beeps" and turn the ignition back on.
Do the above 2 more times.
On thr last time watch the airbag light. It should start blinking slowly. At this point let it blink a couple times and turn off the ignition for 30 secons or so.
You should be fine now.
2006 CC Titan SE 2WD BT. Injen Powerflow, TB Coolant bypass, JBA Evol Exhaust with Maglaflow 24" muffler, Bully Dog Power Pup, Leveling kit, $22 helper springs.
MikeB is offline   Reply With Quote
