Old 02-21-2008, 07:13 AM   #181 (permalink)
hooligan
hooligan's Avatar
Re: "Prerunner" Titan's
Originally Posted by 4wheelpeel
You guys pull the plastic liner from under the front wheel wells so dont you worry about water getting splashed up and sucked into the intake under your fender. I still have my plastic splash guards but because of my bumper I worry about water getting up in there. I crossed a creek about 6in deep once and it got water on my airfilter and ran like crap until I put a spare dry one in. What do you think?
yeah, it helps. have you seen the plastic fender-liner on the XE models? they have more coverage, don't know why either. also you could, if you have an aftermarket cone filter, get a prefilter which is somewhat water-resistant (water splashes) to put over the cone filter. and if that fails you could get a snorkel designed for the titan.
most of us with prerunner glass or FRP fenders have to pull the plastic liner out cause the prerunner fenders run wider and the tabs on the plastic liner just dangle loose. so you either have to yank em out or trim them like i did, but gonna have to remove once i get the shock hoops put in.
PRGsite <> PRG/ID prerunner fenders
