Old 02-24-2008, 06:52 AM   #57
Big Don
Big Don's Avatar
Exclamation Re: Nissan Titan History (Model Year Changes)
2008.5 Standard Features:
1. Mechanical
* VK56DE – Endurance 5.6-liter DOHC 32-valve V8 engine
* 317 hp @ 5,200 rpm
* 385 lb-ft of torque @ 3,400 rpm
* Emissions – LEV
* Continuously Variable Valve Timing Control System (CVTCS)
* Nissan Direct Ignition System
* Platinum-tipped spark plugs
* Electronic drive-by-wire throttle
* Alternator (130 amps)
* Battery (650 CCA)
* Fuel tank skid plate
* Front engine/rear-wheel drive
* 5-speed automatic transmission with Tow/Haul Mode
* Final gear ratio (2.94); similar to a 4-speed automatic 3.73 ratio
* Front vented disc/rear vented disc brakes
* 4-wheel Anti-lock Braking System (ABS)
* Electronic Brake force Distribution (EBD)
* Front: Independent double-wishbone with stabilizer bar
* Rear: Multi-leaf with solid Dana® axle
* Engine-speed-sensitive power-assisted rack-and-pinion steering
2. Exterior
* 18" x 8.0" 6-spoke aluminum-alloy wheels
* P265/70R18 Tires Goodyear® Wrangler® raised outlined white lettering
* Full-size spare tire
* Chrome bumpers and grille
* Black door handles
* Dual black power heat outside mirrors
* Locking tailgate with dampened assist
* Cargo bed light
* Bed rope hooks, stake holder, and separator/shelf provision
* Rear privacy glass
* Power back window
3. Interior
* Air conditioning with rear floor ducts
* In-cabin microfilter
* Cruise control with steering-wheel-mounted controls
* Power door locks
* Power windows
* Remote keyless entry with remote front windows down
* Tilt steering column
* Variable intermittent speed-sensitive windshield wipers
* Door courtesy lights
* Digital compass
* 12-volt DC power outlets
* Digital clock
* Retained accessory power
* Battery saver
* Six cup holders and two bottle holders
* Grocery hooks (rear cab)
* Overhead center console
4. Seating and Appointments
* 40/20/40-split bench front seat with center console or front captain's chairs with driver-side manual lumbar
* Fold-down front passenger's seat (N/A with split bench front seat option)
* 60/40-split fold-up rear bench seat
* Cloth seat trim
* Column shifter with manual shift mode or leather-wrapped floor-mounted transmission shifter
* Leather-wrapped steering wheel
* Metallic-tone accents
5. Audio
* AM/FM/in-dash 6-CD audio system
* MP3/WMA CD playback capability
* Auxiliary audio input
* Eight speakers
* Satellite radio pre-wiring¹
6. Safety and Security
* Nissan Advanced Air Bag System with dual-stage supplemental front air bags with seat belt sensors and occupant-classification sensor
* Front-seat Active Head Restraints
* 3-point ALR/ELR passenger seat belt system (ELR for driver)
* Front seat belts with pretensioners and load limiters
* LATCH System (Lower Anchors and Tethers for CHildren)
* Zone Body construction with front and rear crumple zone
* Hood buckling creases
* Energy-absorbing steering column
* Pipe-style steel side-door guard beams
* Tire Pressure Monitoring System (TPMS)
* Vehicle Security System
* Nissan Vehicle Immobilizer System
The dealer told me that my new 2008.5 Titan has a bigger payload, it is now 2063 lbs, which makes this truck a 1-Ton. That's right baby she's all grown up now!
Big Don is offline   Reply With Quote
