02-24-2008, 03:20 PM
#14
Re: anybody done an IAT mod?
If its messing with AFR and "tricking" the ECU it is going to do one of 2 things....
1) can run too lean since the ECU will not know what the correct temp and airflow (also elevation changes air desity and truck wont adapt), you know are a prime candidate to burn a hole in the piston and launch the motor.
2) Dumps too much fuel constantle (giveing worse milage) and burning up the CATs that we all know are too close to the block and prone to failure from high heat and unburnt fuel. CATs break apart and suck back into motor launching it as well.
I cannot believe these asshats on ebay are still allowed to false advertise and are not fined, arrested, and beheaded. Taking advantage of people ever since the hoax with the "turbonator". New rule of thumb. Pep Boys does NOT i repeat does NOT sell performance parts lol
'06-Uprev/Stillen Longtubes/JBA Kat-bak/S&B/ 4"Ram/PGM/Trutrac...
