Old 03-03-2004, 09:27 PM   #4 (permalink)
Half Shovel
Half Shovel's Avatar
This warped rotor thing was a big problem with early Tundras (mine had 2 sets of rotors replaced).
Don't accept machined rotors. That's baloney on a new truck. It's a warranty issue at this point, and you should insist on new ones.
Make DARN sure that the wheels in the front are torqued to factory specs. The early Tundras were coming from the factory with the rims over-torqued, which will almost always warp your rotors.
Also, when they put on new rotors, make sure they replace the pads as well.
HS
Half Shovel is offline   Reply With Quote
