Re: Prg Heavy Duty Shackle Install W/ Pics
Alternatively, if you have the right jack stands, you can jack up and support the frame on jack stands, then put the floor jack under the pumpkin and use that to ease leaf spring tension so you can pull the bolts. No pry bar required using that method.
