Old 02-26-2008, 04:39 AM   #14
54warrior
54warrior's Avatar
Re: Prg Heavy Duty Shackle Install W/ Pics
Originally Posted by bestatchess
Alternatively, if you have the right jack stands, you can jack up and support the frame on jack stands, then put the floor jack under the pumpkin and use that to ease leaf spring tension so you can pull the bolts. No pry bar required using that method.
That's what I did, although it was a struggle to reach that high because of my lift.
One thing for everyone to keep in mind, the install is a bit more involved if you have a bedside lockbox. It's still pretty easy though for the DIY'er
Watch gas hit $6 a gallon. We'll drill then. You'll see the tree huggers b1tching because at that point it'll cost $100 to fill up their gay Prius'.
"The American Indians found out what happens when you don't control immigration"
