Originally Posted by bestatchess
Alternatively, if you have the right jack stands, you can jack up and support the frame on jack stands, then put the floor jack under the pumpkin and use that to ease leaf spring tension so you can pull the bolts. No pry bar required using that method.
The rear is taller than the front and I don't want to purchase or haul around a big rig floor jack.As it is when I adjust the coilovers I have to use 4 2x4's x12" long screwed together to get her high enough. As far as the prying, its only about 1" no biggie.
