Originally Posted by kimvansa
I checked the oil level today and it is low, I asked this question on the tech threads alongwith my leaking rear seal and realy need some help here.... "on trying to find the 75W140 synthetic oil on the island I drew a blank, they have the 75W90 Redline and can order in the 140 but it will take at least 3+ weeks so if it's low what would anyone recommend I use. They also have the dino 140 grade."
I'm assuming you mean the rear differential. In that case
SYNTHETIC 75W-140 is the oil you
must use. Many different companies produce the gear oil so you don't have to just get Redline. Many people here use AMSOIL, Royal Purple, Redline, Mobil1 and the list goes on. If it were me, I would not go cheap on my differential oil. If you order it from amsoil.com (Severe Gear 75W-140), it usually take a couple of days to get it at the most.
As far as the leaking seal, if it's under warranty take it to the dealership and have them take a look at it.
If you have any more questions, please let us know so that we can steer you in the right direction.
285/70/17 BFGoodrich All-Terrain T/A KO
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (
Still need to install these...)
