Old 03-03-2008, 01:23 PM   #9 (permalink)
bestatchess
Re: hardwire radar detector
You can tap the lighter socket circuit at the fuse panel in the passenger side dash using a Littlefuse mini blade add-a-circuit. Then you can easily run a wire under the dash, along the firewall, to the other side of the cab. There are markings on the inside of the fuse panel cover. IGN indicates which one is switched with the ignition. BAT indicates which one is always powered.
