Old 03-08-2004, 09:44 AM   #8 (permalink)
botran
Originally Posted by superdelish
My right headlamp is higher than my right, so need to adjust. Looking in the manual, it is a little confusing how high the beams should be. I am attaching the diagram. Am I just missing something here?
It is confusing. It would be easier if they just printed H height. Instead I believe you can get the correct aiming with those dimensions because the 53.2 mm dim and 13.3 mm dim will only exist when the H value is set correctly( trigonometry). In other words measure the beam pattern and adjust till you get the 53.2 mm and 13.3 mm values. Once you do the H will be set properly. Unless I'm totally missing something
Brian
botran is offline   Reply With Quote
