Re: JBA Short Tubes Finally
Originally Posted by roy365
The small leak will throw a code everytime on a header install. Mine did come loose after a week or two. Just had to retighten. You will know if that happens. And you will feel more of difference after your second and maybe third tune. Those generic tunes are ok to start on....but be careful you may be lean and dont want to push it too hard. Definitely drive it for a 100 miles or so, then do a few good runs to log. The second tune will be much better and safer I am sure. I actually LOST power before i got Uprev to tune my JBA shorties. After that it was all good though.
Arnt there bolts that a specifically for headers that wont loosen up with the heat? So, you wont have to re-tighten them every once in a while. Im curious, How did you lose power by adding headers?
NEXT MOD: UPREV And Trutrac
MODS DONE: K&N FIPK Intake, Throttle Body Spacer, BANKS exhaust, 6" Pro Comp Lift, SAW Coilovers with PRG Upper Control Arms
