Originally Posted by jcoxtitan
If i put a coilover kit on a 2wd 06 titan that gives 3-4 inches of lift and a rough country 3" leveling kit, does anybody know someone that has done this and what the total inches of lift is or around? I'm looking to do this and it is the cheapest and easiest way I have found. THanks
You can't use that coilspacer with the coilovers. PRG does sell some C/Os that you can add like a 1" spacer to, with a set of new UCAs for about 5" of lift.You can however get the CST 4" Spindles and a set of C/Os for about 8" of lift. IMO this is the best setup for a 2wd. It will yield excellent offroad performance, make your truck ride better on the road, and the C/Os are adjustable from 0"-4" of lift so you can set it up for what best suits your needs.
