Thread: Coilover Kit
Old 03-04-2008, 09:13 PM   #4 (permalink)
Megw3788
Megw3788's Avatar
Send a message via AIM to Megw3788
Re: Coilover Kit
Originally Posted by jcoxtitan
Thanks, I will prob never drive the truck offroad so that performance isnt that important just cheapest way to height, and road ride. That is all I'm looking for, and I am just confused on all nissans different suspension set up's, what's your opinion on someone building a component box like in a fabtech suspension lift to give around 3 or 4 inches of lift to the lower control arm with the coilovers that would add 3 more, My dad is a master welder and fabricator and can build anything with a picture. Thats why i ask.
Well a cheaper route, over the C/Os would be the Spindles and a leveling kit for 6.5" of lift. That setup should run $1k or a bit more if I'm not mistaken. It will retain the factory ride unlike that bracket lifts, look better because there's no subframe hanging down, and be easier to install/remove.
I'm not sure what you mean by "component box", are you talking about the subframe maybe? If you are talking about basically building your own bracket lift, I'd say you would be better off to just go with the spindles and Coilspacers. A good set of C/Os for a bracket lift are like $1200, not to mention all the money you would spend on materials and your time. And this is a proven setup, so there wouldn't be anything to go wrong. If you're not talking about building your own bracket lift, please explain what you mean so I, as well as others can try to help you out.
Megw3788 is offline   Reply With Quote
