Re: JBA Short Tubes Finally
Originally Posted by pedalhappy1053
Arnt there bolts that a specifically for headers that wont loosen up with the heat? So, you wont have to re-tighten them every once in a while. Im curious, How did you lose power by adding headers?
The difference in exhaust temp and volume of the i.d of the header will throw the O2 sensors off. In turn, the computer thinks its running lean which will throw it into 'safe mode' and dump fuel, which will make you lose power.
BTW, just check to make sure the bolts are tight on your manifolds for the first 2-3 weeks. I checked 3 days after the install then once on the weekend to make sure. They were fine after the re-check.
Darkblueta
1998 Trans Am.
Engine, Turbo, intercooled, alky-water injection, 12 bolt, suspension, self tuned and a hell'va lot of fun.
2007 Nissan Titan XE
Daily driver. Beta Testing for Hypertech
