Old 03-04-2008, 08:51 PM   #16 (permalink)
Darkblueta
Darkblueta's Avatar
Send a message via AIM to Darkblueta
Re: JBA Short Tubes Finally
Originally Posted by StuntDriver06
then length of the tubes...
lol, j/k. actually the length of the exhaust tubes of the header are different. Generally the long tubes make more power on the low end and short tubes make more power on the top end. has to do with exhaust flow and velocity.
im sure others will chime in with a better explanation.
Both shorties and longtubes make more power then stock manifolds(depending on the design....99% of the time this is true other then LSx engines, where buying shorties gains you a whole 3rwhp if you're lucky).
Shorties are usually good for a vehicle that needs to go through emissions in states like Kommiefornia because they check to make sure the kitties underneath are in the stock location. This is why long tubes are not always 50 state legal, because they more the kitties back farther and the CARB/EPA nazi's think the cat doesn't work as well.
Long tubes actually make more power then shorties all across the board, but especially down low. Most people I know run an off-road pipes with Long Tubes, but you can still run kitties if you choose.
Darkblueta
1998 Trans Am.
Engine, Turbo, intercooled, alky-water injection, 12 bolt, suspension, self tuned and a hell'va lot of fun.
2007 Nissan Titan XE
Daily driver. Beta Testing for Hypertech
Darkblueta is offline   Reply With Quote
