Old 03-09-2008, 08:19 PM   #67 (permalink)
tech12volt
Supporting Vendor (Gold)
tech12volt's Avatar
Re: Travelship's install
Originally Posted by travelship
Fixed the shifter, the spring clip holding the shift cable had come loose on side. Everything's good now, truck starts.
Finished installing the Cleansweep. I attached a piece of angle aluminum to the little tab on the fan blower assembly, then made a masonite shelf to sit on the angle at the back and attaches at the front to the plastic lip under the glove box door. Very solid, the only thing is I have to remove the Cleansweep to remove the glove box in the future.
Started on the amp rack overlay, got about a hour and half into it before I violated the measure twice/cut once rule. Long story short...I need to get another piece of masonite and start over. Can't work on it tomorrow, so it'll have to wait until next weekend.
Attachment 57757Attachment 57754Attachment 57755Attachment 57756
I love Masonite so easy to work with. Nice job man gald to see it working out.
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
