Old 03-10-2008, 08:58 PM   #28
BECHLYF
BECHLYF's Avatar
Re: SAW Extended Lenght Coilovers Installed
Originally Posted by hooligan
oem shocks are filled with a foam cell. you'd be lucky if it WAS gas-charged. and just for your info bech, the front was lower the last time you saw it cuz it was sitting like warrior's prior to that meet, but i took the preload out so it would perform better in the desert, which it did. anyways warrior, truck look daamn gud and trust us, you'll love the SAWs and the no sway bar ride offroad... heck at least you're still not rolling on stock wheels like bech...
Dude, I was just messing with your BIG MONSTER HEAD! And FYI I had Pro Comp wheels but ditched them cuz I wanted to Pinch the 12.50's and put them in the sweet spot. less rubbing and more clearance up front(with stock off set and width) As for the rears YOUR tires stick out more. When I pull the bedsides the tires WILL tuck under nicely, WILL YOURS! try not to buckle your bedsides trying. Oh well, if you do theres always glass bedsides
Sorry about the jack 54warrior
