Old 03-11-2008, 06:35 AM   #2 (permalink)
Fox Delta
Fox Delta's Avatar
Re: the passenger side back tire sticks out
how about a few pictures to help see whats going on? Did you check for loose/missing nuts/bolts on the rear suspension? Doesn't really make sense....
Did you install the wheels/tires? Maybe the tire shop guy screwed that one up!
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
33x12.50/17 Mickey Thompson MTZon Factory OR wheels
Cherry Bomb Extreme Exhaust
Fox Delta is offline   Reply With Quote
