Re: Bilstein Adjustable 5100's
Ill answer it here. You can NOT, repeat NOT, add any lift to the Bilstein 5100 front struts and keep the spacer lift. We do make a small spacer that you can use with the 5100 on the stock or 1" position but you MUST use a longer bumpstop. I also do NOT recommend using the Bilstein (either the HD or the 5100) with any lift kit. You will crush the bottom of the Bilsteins as the bodies are much longer than a stock shock and the kits are not designed with this in mind. I learned the hard way and had to eat a bunch of Bilsteins when they first released them.
