Re: No brake lights or turn signals on trailer
His Armada may be grounding out to the frame since its made differently than the Titan. Titan's ground back to the battery. therre fore, that white wire going to the trailer needs to run to the back of the lights where the nuts go on. TRUST ME. BCM just controls if you got the wires backwards. if you hook up a ground wire to the turn wires, you will mess somin up seriouly. just hook a londer wire from the ground wire to one light bolt on the back of the light of the trailer. if it doesn't work, NISSAN is suppose to honor you recall, but you should have done it a long time ago. they may not have none in stock. this is a volentary recall so it might have expired too.
I am a nissan employ, I will answer all your questions. I am also a good shade tree machenic.
///YOUR SIG IMAGE HAS BEEN REMOVED FOR BEING FRIGGIN' HUGE! PLEASE RESIZE TO 300X200PX OR LESS\\\
