Old 03-12-2008, 08:36 PM   #5 (permalink)
young dank
Re: lt & rt turn signals
Originally Posted by SaltyTitan
99% of the issues turned out to be the ground of the light. I've rewired my boat trailers so that all the lights have a common ground. I've also used the TRUCK as the grounding point. Not that it's useful at this point but try checking the groud to the light and make sure you have a good ground coming from the truck to the Trailer. Just my 2 cents. Good luck!
exactly, but you also might wanna get a test light and check your fuses under the dashboard on driver side and passenger side and under the hood to the right of the tow and light relays.
I am a nissan employ, I will answer all your questions. I am also a good shade tree machenic.
///YOUR SIG IMAGE HAS BEEN REMOVED FOR BEING FRIGGIN' HUGE! PLEASE RESIZE TO 300X200PX OR LESS\\\
young dank is offline   Reply With Quote
