Originally Posted by campsmoke
Hi karle
What effect would putting a set of LT-Load range E's have on the payload capacity of the King Cab LE 4x4? Does this application increase the payload capacity? My 2000 Tundra had no problem with my current payload! Surely the Titan could Handle it! But I do not want to make a mistake at this point! I notice that the 2004- F150 has a payload capacity of 2,690 lbs. What up with that?
Like Darryl said, when it comes to comparing the cargo capacity to the Ford you have to compare apples to apples. For example, crew cab to super crew capacities are almost identical. The same probably goes for king cab to super cab.
The LT tires will provide increased load carrying ability and stability. I hate telling people to go out and get things they think they may not need (as everyone has there own comfort levels) but you have a lot of weight to pull around and you're going to need all of the safety and stability you can get. For example, although the manual says the capacity on my SE is 1485 lbs, the tire safety sticker on the side of my door said not to exceed 1200 lbs. I think you will be fine, just put as much in your trailer as possible (i.e., the wife, kids, toys, etc...just kidding!).
Karl
2004 Titan SE CC RWD, Canteen
Utility Bed Package
SE Preferred Package
Sliding Bed Extender
Sliding Tool Box
Hood Protector
2003 Toyota 4Runner 4x4 V8
2004 Arctic Fox 22H Travel Trailer
Truck and RV
