03-12-2004, 06:17 PM
#3 (permalink)
Originally Posted by CI338
Decided to change the muffler tonight. You know, one of those, 'Lets violate the warranty' type deals. That little bastard of a pipe necks down to 2 1/4" on the inlet and outlet of the muffler. My calipers only measured 2.5" on the main pipe in and out. So, whatever you do, don't put a glass pack in place of the muffler. It will be louder that hell- no problem, just that the resonance is killer inside the cab, but only from 1500-1800 rpm... right at 55mph in 5th. Those factory cats must flow well, that truck has a hellish volume to it. I'm thinking flowmaster(on my other truck, sounds fine) or dynomax ultraflow( they make a long version that will absorb sound) or a second muffler for sound cancellation.
Yes, I know factory exhausts are tuned to elimate resonance and all that, but damn, the Titan sounds pretty good opened up. I may go out an G-tech it later to see if I killed any power. I can always try flowmaster later.
I'm the type to try different exhausts. On my Z28, I had to swap mufflers till I found something I liked. Same on my old Dodge.
How did violate the warranty? Adding a muffler wont void it. It will void your Exhause warranty but not the truck warranty.
2008 4x4 Titan SE
2007 G35 (her ride)
2006 Cummins 4x4 lifted on 37's (work truck)
2004 GTO black on black 11.24@121
"why does your car idle like that"
