Re: lt & rt turn signals
99% of the time it's the trailer, unplug and check the trucks 7 pin connector to make sure it's all good coming out of the truck...This should be the first thing done when having trailer light issues...then you can move on to the trailer.
This is more likely to happend the the ground being a problem, do you have LED light on the trailer? if not I would also check the bulb, could have burned out if only the brake and turn signal isn't working
2006 LE 4X4 Crew Cab Galaxy Black Big Tow, OFF-Road, Nav, Sunroof
Current mods 2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
