Re: Running an Accessory while Towing
Did you test with the key in the ignition and turn to on? There is not power to the plug unless it is turned on by the key; safety feature so if the trailer is hooked up for an extended period of time is doesn't drain the battery
2006 LE 4X4 Crew Cab Galaxy Black Big Tow, OFF-Road, Nav, Sunroof
Current mods 2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
