Old 03-14-2008, 07:31 PM   #33 (permalink)
Dr. Chaz
Re: Eliminating AT fill tube
Originally Posted by 54warrior
Congatufreakinlations!!!
That's just plain ignorance if you ask me. Sure glad you're not my doctor!!!
Every one has their right to opine. However you missed the point. I check if necessary and service when necessary. The tube elimination is due to the fact that no service is required unless it’s time for a change or due to a leak as no fluid is consumed during operation.
How many people ask the question, the how do I check my ATF? Well the procedure indicates to: See Attachment, hope it made it...
At the beginning of the procedure it cautions not to overfill, the ‘NOTE’ indicates how the fluid level is greatly affected by temperature. Are you checking at the proper temp to determine the proper level?
I believe the stick gives a false sense of security as you could be over or under full by a pint or more! But then I’m a stickler for detail. As I mentioned before, with a non tube system there is a level plug like a differential, (while operating in neutral) if you get a ‘slight splash’ it’s full, no splash add, if it overfull it drains out to the proper level.
If you suspected a loss of differential fluid, how would you check it? Do you feel deprived there is no stick for the differential?
I typically keep a vehicle in service for 200K, by then I’m tired of the ride and purchase something new. So far my maintenance practices have served me well over the past 35 years; dumb luck I guess. As I started off, everyone has their opinion, and I believe the non tube system is far superior. One caveat, you will need an assistant to add fluid on the top side while checking on the bottom side.
Dr. Chaz is offline   Reply With Quote
