Old 03-15-2008, 11:49 PM   #20 (permalink)
1bigwhitetruck
1bigwhitetruck's Avatar
Re: No brake lights or turn signals on trailer
My 05 titan had the same problem with trailer lighting. Dealer said that I had a recall. They installed a bcm sub harness that has inline fuses to the turn signal wires. Told me everything now works fine. Well plugged into a trailer and the lights still did not work. Got a buddy that works for an infinity dealer to pull a wire diagram for me and we found out that the bcm was not sending a signal out to the turn signal for the trailer. The truck turn signals worked fine, but had no trailer. Took it to the dealer and got the run around about how my trailer is causing my problem and that I should get my trailer rewired to the vehicle. My trailer works on my 07 titan but not my 05. So I pulled my trailer down to the dealer (me knowing that it needs a bcm) and told them to figure it out. Rewire the trailer to the vehicle if it needes it and if it works I will pay whatever. The tech actually rewired the trailer and the lights still did not work (no surprise). I called the service manager and arranged a meeting to discuss my lighting isssue. Met with the manager and explaned to him what was going on and that I had an infinity mechanic inspect my bcm and found out it was bad. He called in the writer and the tech. The writer and the tech sat there and told me to my face that the bcm is functioning normal. That my problem was in the trailer. Had them plug the trailer into another titan in front of me and the manager and it worked fine. Plugged it into my truck and it don't work. Service manager go very upset that it had gotten to this and replaced the bcm for me for free. If you want I can get the wire diagram for your truck and you can test the two wires and see if you have output.
2007 Nissan Titan CC 4x4 LE, -Daily Driver. Nismo CAI, PowerAid tb spacer, 2 degree advance, 2" Ready lift front kit 1" rear blocks, 35x12.50r18 Toyo open country m/t.
2005 Nissan Titan KC 4x4 Off-Road, -Not so daily driver. Stillen supercharger (3rd motor currently broken), AEM CAI, Custom tb spacer, 2 degree advance, Jba Headers, No cats, 3" straight pipe, 5" RBP tips, true dual exhaust, Pro-comp 6" stage 1 lift, Daystar 2" spacers, 3" custom body lift, Custom rear springs, Modified dana 60 rear axle w/4.88 gears, Modified front GM diff w/4.88 gears, 38.5x12.50r18 Pro-Comp Xterrain. Bare foot gas pedal (one day I will actually fix it and be able to drive it again)
1bigwhitetruck is offline   Reply With Quote
