For less than 5000pds total...you can use a Class III hitch setup and be perfectly fine. Keep in mind towing smaller trailers vice larger trailers are trickier when backing up and if no sway control is on your setup and you go too fast you can have just as many problems. Keep your speed 'reasonable' and you will be just fine
Chris
