Old 03-14-2004, 07:00 PM   #4 (permalink)
cgoulette
cgoulette's Avatar
Window Problem
My Driver Side Window does a strange thing also. If you roll it all the way down, it will not roll up. It's like it forgets it's in the down position and will not roll up. I found a work around for the problem (since it doesn't happen very often, only when it's real cold outside). You roll it down, and if it doesn't roll up, "You Push Down on the button", wait 5 seconds, then Roll Up, and it will roll up. If you continually try to roll it up when it's stuck in the down position, it will not roll up.
cgoulette is offline   Reply With Quote
