Old 03-16-2008, 10:17 PM   #36 (permalink)
loufish
loufish's Avatar
Re: Trailer Left Turn Signal/left brake light not working
You need to check the tow harness coming out of the BCM whick provides both turn signal and brake lights for the trailer.
It seems during a recall for a BCM harness issue, there was a small sub harness replaced for the tow package, and it just might now include a fuse for each turn signal(remember it's also the brake) side.
The trucks turn/brake functions are controlled and wired different then the trailer harness.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
