Thread: Light towing
Old 03-14-2004, 08:22 PM   #6 (permalink)
MZ3Cosmo
Originally Posted by MaxPowers
I don't have the towing package on my truck, but say i wanted to tow a couple of jetskis to the river that probably was a couple thousand pounds. Would i have to buy a hitch or something of that sort or could a ball just be placed onto the bumper since i'm not towing that much weight?
BUY THE NISSAN TOW HITCH/RECEIVER
After buying the Nissan Class III hitch/receiver to my surprise it is the exact hitch from the BIG TOW package with the plugs and relays for the factory wires also included! I installed mine alone in under 20 minutes. It is a little heavy about 50 lbs.! The kit includes the 6 bolts, 2 relays and the 7 pin connector. On the detailed installation instructions and specs sheet it even lists the same 9500lbs rating. We (with out BT option) are limited to 7500 lbs. due to the higher rear axle ratio, but we should be getting better gas mileage when not towing. I could take pictures of it if needed but it is the same as the one you have seen at the dealership.
and she said that size doesn't matter!
MZ3Cosmo is offline   Reply With Quote
