Old 03-17-2008, 01:28 PM   #12
Bullwinkle
Re: Mods to Safely Upgrade Towing Capacity?
Factory tow ratings aside, if I had to tow that much weight, I would install helper air bags, a weight distribution hitch, the appropriate load rated tires, a class V (5) receiver, and get a 10k lb ball & ball mount.
Engine mods will give you more power, but that's not the issue you're dealing with. The issue is in what weight the driveline, axles, frame, and receiver will handle.
'08 Titan SE, Crew Cab, 4wd, LWB, Smoke
Bullwinkle is offline   Reply With Quote
