Re: Mods to Safely Upgrade Towing Capacity?
When loaded, your tongue weight will probably be over 1000 lbs. First, that would exceed the capabilities of the factory hitch. Second, with that, passengers, and cargo, you will likely be over your GVWR. I'm only towing a 5000 lb trailer with a 500 lb hitch weight, and I'm concerned about exceeding the GVWR. The GVWR is 7200 lbs on the 08 models. It's less in prior years.
2008 Titan SE, Crew Cab, 4x4, Long Bed
Popular Pkg w/ Captains Chairs
Utility Bed Pkg, Big Tow
Smoke/Charcoal
Westin Sure-Grip Aluminum Running Boards, Lund Bug Shield, Leer 100R Cap
