Old 03-15-2004, 02:01 PM   #4 (permalink)
bighawaii
follow the steps exactly. porgram it with your hand held opener by it 1st like you would for any garage door. the next step is easier with 2 people but 1 is ok. push the button on your actual garage door openers case (under the light cover or alittle plactic cover usually), immediatly after pushing it push the SAME homelink button you previously programmed with your hand held opener. hope i didnt confuse you even more, good luck!
let your old age be childlike, and your childhood like old age; that is, so that neither may your wisdom be with pride, nor your humility without wisdom.
bighawaii is offline   Reply With Quote
