Old 03-15-2004, 06:38 PM   #5 (permalink)
Deepwater
Deepwater's Avatar
Originally Posted by CaliforniaTitan
All,
It is believed the cause of the problem has been identified and the 'fix' is currently being worked. Once the fix is completed and the test completed with stable results the fix will be pushed to owners.
The issue almost duplicates the problem the 350Z radios had when they were released a few years ago. Many 350Z owners had similar complaints with the Bose audio system at the time. In time, Nissan became aware and has fixed this problem as well.
It should be noted that reporting your current radio problem to the dealer will just more than likely result in another radio being ordered for your truck and probably would not fix your problem at this time until the actual 'fix' completes testing and is released inside the new radios.
I will keep everyone posted with more information as I recieve it and will pass how to actually go about getting the work completed at that time.
Till then everyone, keep your chins up and the smiles plastered on your faces as your overall Titan experience will soon be better
Chris
Chris... Thanks for your info! Did you here this from Nissan or from your dealer?
Deepwater is offline   Reply With Quote
