Originally Posted by havotec1
Hey guys I've tried searching past posts on this topic, I have an 04 XE with off road package, and am trying to wire my electronic brake controller that I hooked to the connector that I bought from my dealer. The problem is finding the piggytail located under the dash by the e-brake. Pretty sure I don't have one, looked under my brothers LE and found it right away. Anyhow I saw a post a while back stating that the 04 XE didn't have the prewired plug? Does anyone know this for sure and if this is the case how would one go about wiring it? Any info would be greatly appreciated.
It's easy... First check to see if you at least have the 4 wires at the rear for tail/turn/brake lights, you should. Then get a couple of circuit breakers (20-30 amp auto reset) and lots of 12 Gauge wire. Run one power wire to the rear of the truck (You can also run it through a relay so it only gets power when the key is on, but get the juice straight from the battery) The other power goes into the cab of the truck for the brake controller. Run a wire out of the cab to the back of the truck for the brake signal wire. and if you want a reverse light tap into the back up light circuit..
E-trailer I think has everything you need in a kit.
'05 4x4 SE, O/R, Big Tow, Rear Video (Kids favorite option). AMP Powersteps, SAW's all around, TC UGA's and Rear Shackles, Modified Deaver Mini Pack, Air Bags, Moto Metal 951's 18x9, BFG A/T 285/65-18's, Banks Ram Air, Banks Monster Exhaust, Bully Dog Power Pup, PML Rear Diff Cover and Trans Pan.
Towing WW FS2300 Toyhauler and all the toys.
The Rhino,
The Titan,
Truck and Trailer
I HIGHLY recommend
PRG Products,
SDR Motorsports,
Live Wire Whips, and
Banks Power
