Old 03-21-2008, 07:39 PM   #102 (permalink)
BECHLYF
BECHLYF's Avatar
Re: TRUETRAC Mag-Hytech Diff Cover AND 3:73 GEARS
Originally Posted by SicEm2005
Try puttin the stock tires and wheels back on and see what kind of burns you get! Im sure the new gears and Tru-Trac will fire them up nicely. The gear changes you did should have just put you back into your stock ratio.
Actually I don't know ? I had 2:94 gear's and 3:73 gear's are 27% lower ratio and I only increased tire size by 10%. With 35's I was doing around 1700 RPM in 5th at 70MPH and know I'm doing around 2159 RPM at 70 in 5th. So I should be getting 17% more RPM's. 17% more RPM than stock tires with 2:94?
