Originally Posted by eurohazard
I'm not sure where you came up with the 8,500 lb towing limit for your Titan. I think the limit for non-BigTow Titans is more like 7,400 lbs. So at 9,500 lbs you're more like 2k lbs overweight. I would not drive like a "mad man" if I were you.
And while the engines are the same in all Titans and Armadas (baring a few tweaks for a few extra HP in later years)......Big Tow is not "have heavier parts for the extreme drivin, and oh and big tow has trasmission cooling system". What are the heavier parts? One big reason for the Big Tow's increased tow rating is the lower gears (higher numerically).
we have different shocks that goes on, different brake actuators and brake boosters, Tires, shocks, transmission coolin system. that's why I said thoses things, all of them have the lower gear ratio withthe tow mode button.
and I survived another weekend of camping, traveling back and forth.
