Re: Wheel Offset?
hey i got a 06 titan i wanna put a 4" ranchero lift on it then, run these tires LT285/70R17 but i dont know what rim will work. i know nothing about what the offset or backspacing should be. help me out guys
here are the rims i was looking at:
Pro Comp Xtreme Alloy Series 7005
Part Number: PXA7005-7883
17x8, 6 on 5.5 Bolt Pattern
Backspace 4.5 in.
Hub Centric No
Max Load 2200lbs
Offset 0mm
Finish Cast-Blast
or
Part Number: PXA7005-7938
17x9, 6 on 5.5 Bolt Pattern
Backspace 4.75 in.
Hub Centric Yes
Max Load 2200lbs
Offset -6mm
Finish Cast-Blast
and does hub centric mean anything?
