Old 03-23-2008, 10:33 PM   #11 (permalink)
NorCal 4x4
NorCal 4x4's Avatar
Re: Amsoil No Good??
Originally Posted by Shane06fl
Yes I read the doc and saved it. Good info to have down the road. My other truck has the 100K mile warranty.
But you know the trany lines at the radiator are really easy to get to. I use to pull those and pump out the fluid while adding fluid until the fluid ran bright red. Always used way more fluid than was needed but hey a quart was only like $1.50. Kinda hard to waste 2 or 3 quarts at $10 A quart
Even if it takes 5 or 6 quarts more, that is still a much better way than the pressure flushes, and cheaper than what the dealers around here wanted for their machine flushes, (when I checked a few years back). All quoted over $300, and one of them wanted $390.
Here's a link to a post, here at TT, that describes the type of flushing you mention.
http://www.titantalk.com/forums/817442-post1.html
NorCal 4x4 is online now   Reply With Quote
